| bonjour ! | |
Frisson membre d'honneur
Nombre de messages : 43659 Date d'inscription : 13/02/2006
| Sujet: Re: bonjour ! Sam 29 Mar - 1:28 | |
| VIN WDB2020181 Model C180 Chassis 2020181 Engine 111920 10 076007 Transmission 717416 05 554260 Order 0 4 531 18700 Approx. year 1994 Lights BOSCH Wiper BOSCH Cab 00000 Dealer France, Monaco (531) Interior cloth black (401) Paint 040 black (T) (с 01.01.1963) Options 240 outside temperature indicator (с 01.03.1982) 260 elimination of model designation on rear lid (с 01.05.1968) 291 airbag for front passenger airbag for front passenger (с 01.10.1993) airbag for driver and front passenger (if driver airbag standard - then only for passenger) 305 dust filter (с 01.11.1990) 341 additional lamp (с 01.09.1982) 538 automatic antenna and front loudspeaker - without radio set (model 500SEC with loudspeaker only) (с 01.10.1989) 543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978) 570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970) front folding armrest w202 - housing at front with armrest 584 electric window lifters (front and rear doors) (с 01.04.1970) electric window lifters, fourfold or sixfold 593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972) 630 ECE warning triangle (с 01.08.1980) 812 rear-mounted loudspeaker (с 01.11.1974) 826 866 Technical changes of modelling year 1995 (с 01.01.1994 по 19.10.1997) 955 extension tube on the roof, front equipment package elegance (с 01.11.1991) 984 elimination of ownership certificate but with coc papers (с 01.06.1993)
Bien optionner cette voiture,
PS : La prochaine fois ne met pas le VIN sur le forum. | |
celts membre bienfaiteur
Nombre de messages : 14363 Date d'inscription : 20/02/2006
| Sujet: Re: bonjour ! Sam 29 Mar - 8:39 | |
| Bon ca doit se trouver la: http://detali.ru/cat/oem_mb2.asp?TP=1&F=202018&M=111%2E920++++++111%2E921&GA=722%2E421722%2E603&GM=717%2E416717%2E417717%2E418&CT=F&cat=44V&SID=54&SGR=080&SGN=06 Par contre il y pas mal de ref, donc faut trier. @Frisson, j'ai caché le VIN. | |
Nombre de messages : 10803 Age : 61 Localisation : 01 modèles possédés : W126 300 SE, R129 500 SL, T124 300 TD 4 matic,S203 320cdi, C124 230E, R170 SLK 230K, C126 500 SEC, W208 CLK 200 Cab., S211 320 CDI. Date d'inscription : 19/08/2007
| Sujet: Re: bonjour ! Sam 29 Mar - 19:03 | |
| Bonjour et bienvenue ( surtout une femme, c'est rare ) Triste histoire que celle-ci. Et c'est bien la première fois que j'entend qu'on ne peut pas reprogrammer de boitier. Les voleurs le font bien eux. | |
reg membre
Nombre de messages : 16 Age : 50 Localisation : NICE modèles possédés : C 180 Date d'inscription : 28/03/2008
| Sujet: Re: bonjour ! Sam 29 Mar - 19:04 | |
reg membre
| Sujet: Re: bonjour ! Sam 29 Mar - 19:06 | |
kash membre bienfaiteur
Nombre de messages : 2454 Age : 49 Localisation : Pas de calais(62) modèles possédés : Mercedes 190 2.6 1988,Mercedes 500 sl 1994,Mercedes 300 turbo D break 1990,Mercedes 300GE "référence" 1992, 2cv,Ami6,Ami8,HY,4cv,Land rover 88,Honda NSX Date d'inscription : 29/08/2007
| Sujet: Re: bonjour ! Sam 29 Mar - 19:24 | |
| Salut Ne vous plaignez pas mes amis ,il lui ont piqués que le boitier Din ch'nord il lui auro piqué el carette complette | |
charles35 as du volant
Nombre de messages : 157 Age : 57 Localisation : rennes modèles possédés : mercedes e250d 1993 e290td 1998 Date d'inscription : 04/04/2007
| Sujet: Re: bonjour ! Sam 29 Mar - 20:17 | |
| mon avis personnel si le boitier la et volé sur ce genre de mercedes les voleurs peuvent l'ai revendre sans trop de problème et pouvoir les décodés a++ bon courage pour toi | |
sl57 champion des champions
Nombre de messages : 1210 Age : 51 Localisation : metz modèles possédés : CLK SL280 Date d'inscription : 26/09/2007
| Sujet: Re: bonjour ! Sam 29 Mar - 20:37 | |
| d apres des infos de chez benz !!!!!!!cela ne ce decode pas maintenant j me suis peut etre fait endormir????? merci de vos infos!!! rien que pour savoir si je mets a l amende le mecano qui m a raconté des conneries!!!!!!!!! | |
reg membre
| Sujet: Re: bonjour ! Sam 29 Mar - 21:01 | |
| c clair qu'ils n'ont pas piqué tous ces boitiers sans connaissance de cause! ils doivent s'y connaitre un peu en mecanique qd meme. c ca qui me rend dingue. quand mercedes me parle d'un mec qui peut etre prend ces boitiers en esperant en faire marcher un sur sa voiture sans avoir besoin de le décoder, ... bref | |
reg membre
| Sujet: Re: bonjour ! Sam 29 Mar - 21:03 | |
| merci celts pour ton lien mais je n'y comprend pas grand chose j'y retourne voir qd mm | |
| Sujet: Re: bonjour ! | |
| bonjour ! | |
