Le traditionnel listing d'options
VIN WDB1290671Fxxxxxx
Model 500 SL
Chassis 1290671Fxxxxxx
Engine 119972 12 xxxxxx
Transmission 722364 03 xxxxxx
Order 0 2 531 xxxxx
Approx. year not defined
Dealer France, Monaco (531)
Interior leather grey / alpaca gray (278)
Paint
929 nautical blue metallic (с 01.01.1984)
Options
216 TeKaDe antenna, roof mounted (с 01.03.1973 по 30.11.1976)
self-levelling suspension all-around, with adaptive damping system (ADS) (с 01.02.1988 по 31.01.1996)
rubber buffer used for emergency running (с 01.02.1968 по 31.12.1972)
model designation plate for harder springs (с 01.11.1962 по 30.11.1966)
241 left front seat electrically adjustable with memory feature. only applicable to w 210 when installed in conjunction with code 275. (с 01.03.1983)
wood rims (с 01.01.1964 по 31.08.1971)
242 right front seat electrically adjustable with memory feature. only applicable to series w 210 when installed in conjunction with code 275. (с 01.03.1983)
spare wheel, without tire (с 01.01.1964 по 31.08.1971)
246 heated rear window pane, heat-insulating, single-sheet safety glass (с 01.04.1970 по 30.06.1972)
standard tires qty. 5 loose in trunk (с 01.11.1965 по 28.02.1968)
mirror with memory circuit (с 01.02.1988 по 01.09.1996)
281 trunk set, (280 SL)
trunk set, 3-piece (с 01.09.1972 по 30.11.1976)
trunk set, 4-piece (с 01.04.1963 по 31.01.1966)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990)
steering wheel (390 mm) with sports design (с 01.03.1989)
283 trunk set, 4-piece (с 01.02.1967 по 30.11.1976)
trunk set, 6-piece (с 01.01.1962 по 31.01.1966)
draft deflector (с 01.07.1989)
291 airbag for front passenger
airbag for front passenger (с 01.10.1993)
airbag for driver and front passenger (с 01.07.1987 по 30.09.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
garment trunk, large (с 01.02.1967 по 31.05.1973)
trunk set, 7-piece (с 01.01.1976 по 31.08.1978)
406 single seat with orthopaedic front seat backrest, left and right (с 01.07.1970)
seat bench (с 01.01.1962 по 31.07.1965)
440 bumpers with guards, front and rear (с 01.10.1970 по 30.04.1974)
bumper with horn and rubber buffer front and rear (с 01.03.1964 по 30.09.1970)
tempomat (cruise control) (с 01.09.1975)
531 automatic antenna (с 01.01.1963)
565 rear seats used on sl models (с 01.01.1963)
581 Thermoking air conditioner (с 01.04.1970 по 31.12.1972)
automatic climate control (с 01.01.1977)
592 wyellow foglamps (с 01.01.1963 по 31.10.1965)
heat-insulating glass, all-around, heated rear window pane (laminated glass), band filter
heat-insulating glass, side window panes (с 01.02.1967 по 31.01.1971)
green heat-insulating glass all round, heated rear window, laminated safety glass - tinted strip (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
trim strips on hardtop (с 01.04.1963 по 31.07.1971)
610 bulb for main headlamp yellow (с 01.02.1963 по 31.10.1965)
headlamps and fog lamps and additional bright light with amber lenses (с 01.11.1965 по 31.03.1994)
halogen lamp unit, amber (с 01.04.1994)
630 ECE warning triangle (с 01.08.1980)
radial-ply tires (с 01.03.1966 по 31.10.1974)
Michelin x tires (с 01.08.1963 по 31.08.1965)
652 Dunlop tires (с 01.01.1963 по 31.07.1972)
8-hole light alloy rims (с 01.01.1990)
740 folding top fabric9001 black (с 01.08.1972)
756 Becker radio Mexico 2000 (с 01.06.1990 по 31.03.1994)
radio MB Audio 10 CD with vk and RDS (с 31.10.1996)
810 roof-mounted loudspeaker (с 01.11.1962 по 30.11.1972)
loudspeaker, sound package
sound package (bose) (с 01.12.1986)
826 (Alarme serpistar pour la France)
857 new shift-/selector lever generation br 140 (с 01.01.1990)
873 seat heater for left and right front seats (с 01.02.1984)
Pascal
